Use this task to configure MAC-offset for a Management VLAN instance.
    enable
    configure terminal
  2. Enter the MAC-offset for a Management VLAN instance:
    mgmt vlan mac-offset <0-511>
Configure the MAC-offset for the Management VLAN instance:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#mgmt vlan
Switch:1(mgmt:vlan)#mac-offset <0-511>
The following table defines parameters for the mgmt vlan interface.
Variable
Value
mac-offset <0-511>
Specifies a number by which to offset the MAC address from the chassis MAC address. This ensures that each IP address has a different MAC address. If you omit this variable, a unique MAC offset is automatically generated.
